itskamel
Jul 09, 2017Tutor
X10 R9000 Wireless Roaming
I recently changed to a X10 and had previous wireless roaming setup. The 2.4 band is fine. However with Netgear wifi analystics app I can See 2 different 5ghz bands. They are named Identical. Anyone ...
- Aug 13, 2017
Hi itskamel,
The R9000 does not support wireless roaming. It will be listed as a different network even if you name it same as other networks.
