maddly2000
Dec 11, 2016Guide
X10 r9000 wont stay connected to xbox one s
I had an Asus rt87u that worked perfectly. I upgraded to the r9000. I have kids and a very connected home with typically 8 to 10 devices on the network. All work fine wired or wireless except my xbox...
- May 12, 2017
Well, I owe Netgear and the Community an apology. Turning of the Xbox Instant On feature solved it. Now I can start hounding Microsoft.
May 09, 2017Guru - Experienced User
Try the other suggestions as well on 5Ghz or downgrade FW. IF this is happening on both wired and wireless. Could be a different issue.
Let us know how it goes.
maddly2000
May 12, 2017Guide
- FURRYe38May 12, 2017Guru - Experienced User
Good luck in getting them to fix that. Been a problem since the xb1 came out. Glad yours is working now.
- Sac2uneakJul 18, 2017Aspirant
My Xbone is "instant on" and I STILL have the same issues. I've got the QoS turned on, and speed test done, I've got static IP, opened necessary ports for gaming, etc. It also, is hard-wired with a cat-6 cable. So, I don't thinkl you owe ANYONE an appology. THere's something odd about this SUPER expensive router, NOT doing its job. I have a feeling it wants to block our xbox from the network, thinking it's not allowed to take up bandwidth....when...well....it's the exact opposite!
Even if turning "instant on" to OFF....why would it be affected? Why would I LOSE that feature on my Xbone? That doesn't make much sense!
Sorry, you can't come out of standby mode to use this router because it's 1992!"
