maddly2000
Dec 11, 2016Guide
X10 r9000 wont stay connected to xbox one s
I had an Asus rt87u that worked perfectly. I upgraded to the r9000. I have kids and a very connected home with typically 8 to 10 devices on the network. All work fine wired or wireless except my xbox...
- May 12, 2017
Well, I owe Netgear and the Community an apology. Turning of the Xbox Instant On feature solved it. Now I can start hounding Microsoft.
maddly2000
May 12, 2017Guide
May 12, 2017Guru - Experienced User
Good luck in getting them to fix that. Been a problem since the xb1 came out. Glad yours is working now.
