nselewa
Sep 19, 2018Guide
X10 R9000
internet connection being dropped by x10
Have the latest firmware as of today 9/19/2018
When wired in, no issues
I brought out my much older netgear router running on a different channel, no is...
- Sep 19, 2018Do you have “Access Control” enabled, and/or can you see your devices? I’ve had issues of losing my devices after editing a device from the Access Control page. I then would get numerous internet drops. I fixed this by doing a hard reset, and if you happened to save the config when everything was okay, you can rebuild the settings faster.
dwstanley
Sep 19, 2018Aspirant
nselewa
Sep 19, 2018Guide
Access control is on
I've seen posts here where people have done a hard reset and it has not solved the issue.
I guess i can try that next, but I'm not confident that it would help given other peoples experience in doing that.
- dwstanleySep 19, 2018Aspirant
I've been running with Access Control and QoS enabled so far so good, however, I make no changes on the Access Control page.
