Juanlanas13
Jan 27, 2017Aspirant
X10 slow speeds over wireless
I just a netgear nighthawk x10. Wired i have 200 mb wired i have 20. Can you please help. My modem is a cm600. Thank you.
- Feb 08, 2017The factory reset worked. Thank you.
ElaineM
Jan 30, 2017NETGEAR Employee Retired
Welcome to the community, Juanlanas13
Just to verify, what's the wireless speed you're getting on your wireless?
What's the wireless adapter being used on your wireless device?
What are the wireless clients? Are they laptops, mobile phones, tablets?
Did you try changing channel on the router?
Which signal are you connecting (2.4GHz or 5GHz)?
Make sure to avoid other wireless devices that may interfere with the wireless connection.
See the link below for more information.
