Juanlanas13
Jan 27, 2017Aspirant
X10 slow speeds over wireless
I just a netgear nighthawk x10. Wired i have 200 mb wired i have 20. Can you please help. My modem is a cm600. Thank you.
- Feb 08, 2017The factory reset worked. Thank you.
Juanlanas13
Feb 04, 2017Aspirant
My wireless speeds are 17 mb on my lg v20. 20 on my labtop with ac wireless. Ive tryed changing the channel serval times with no luck. I enabled wmm and it went up to 50 mb but a day later it went back to 17 mb. Wired i have 280 mb.
ElaineM
Feb 07, 2017NETGEAR Employee Retired
Try to factory reset the router and observe your connection.
By the way, factory reset will wipe out all the settings so I suggest that you reconfigure it from scratch.
