JR111's avatar
JR111
x2goclient doesn't work in a VPN connected PC
To duplicate the problem:
* VPN to the router
* Run x2goclient connecting to a ubuntu 18.04 server.
The client never receives a response from the server.
This problem occurs with x2goclient in windows and ubuntu 18.04.
The problem is caused by the router not assigning a Lan IP address to VPN connected PC. Thus, the PC isn’t operating within the router subnet space.
  • FURRYe38's avatar
    Is this in regards to a NG router product? If so, which model please?
  • I added the model number: R7000 - AC1900 Smart WIFI Router
    • JR111's avatar
      JR111
      Problem solved.
      The source of the problem was the network provider's hardware configuration missmatch. The provider was disconnecting the network after the hotspot connected.
      x2go works now.
