orsajakt
Sep 02, 2022Aspirant
X4S and XR500 on the same network
I have a Netgear Nighthawk X4S AC2600 Smart WiFi Router and a Netgear Nighthawk pro gaming XR500 Gaming Router. Each is in a house. Between the houses is an Ethernet cable a little over 100 m lon...
- Sep 02, 2022
orsajakt wrote:The ONT has LAN1, LAN2, LAN3 and LAN4 but only LAN1 is used (connected to X4S).
That sounds correct. The only thing worse than two devices on a LAN trying to function as a router, would be three.
Configure your X4S as a router and your XR500 as an access point and see how it works for you. Remember, some router features are disabled in access point mode. https://kb.netgear.com/000061927/What-is-the-difference-between-router-mode-and-AP-mode
orsajakt
It is an Optical Network Terminal but I did not find a model number on it. Only a MAC number.
Kitsap
Sep 02, 2022Master
The question is, does the ONT perform any routing function?
Does the ONT have more than one Ethernet output port?
- orsajaktSep 02, 2022Aspirant
- KitsapSep 02, 2022Master
I have changed my XR500 to access point mode and everything worked as usual so far.
