TBy's avatar
TBy
Tutor
Jul 08, 2018
X4S File copied over the network fail MD5 checksum and are corrupted
 I have the X4S configured as an access point. I have a PC connected to the X4S via ethernet cable. Files copied over the network consistently fail MD5 checksum. I've searched and found a related pos...
  • KristinaS's avatar
    KristinaS
    Jul 09, 2018
    by the way for a test you just need to disconnect you cable from internet port and to attach it to the internet port. two seconds. and i beat you will not have such md5sum problems anymore.
