TBy
Jul 08, 2018Tutor
X4S File copied over the network fail MD5 checksum and are corrupted
I have the X4S configured as an access point. I have a PC connected to the X4S via ethernet cable. Files copied over the network consistently fail MD5 checksum. I've searched and found a related pos...
- Jul 09, 2018
by the way for a test you just need to disconnect you cable from internet port and to attach it to the internet port. two seconds. and i beat you will not have such md5sum problems anymore.
KristinaS
Jul 09, 2018Apprentice
TBy wrote:
The manual states to connect the X4S Internet port to the LAN port of the other router which is how it is/was configured. I take it the "Internet" port is what you reference by "WAN" port. Is there reference that your method should work?
i had the same issue with my r7800 in ap mode. there were broken files transferring them with readyshare or ftp. manual is wrong. i have connected my router to the lan port instead of internet port and now it works as it have to do. i am using it connected to lan port during one year and do not have such problems amymore. one year of testing is enough?
KristinaS
- TByJul 10, 2018Tutor
OK! Using just the LAN ports and not the "Internet" port fixed the problem. I wish I would have thought (or known) just to move the ethernet cable before taking down and swapping out the router.
Appreciate all in this thread and patience! I hate when the manual is wrong!
- antinodeJul 10, 2018Guru
> problem. [...]
Interesting.
> [...] I hate when the manual is wrong!
Or when there's a hardware/firmware problem such that the router
fails to perform as designed/specified. (When your car doesn't start,
do you complain about the car or the car's owner's manual?) - KristinaSJul 11, 2018Apprentice
i think it is rather bug in the stock ng firmware. but using lan port is a workaround. by the way i would advice to use voxels fw
it is like a stock but with fixed bugs and faster/stable. could be flashed over stock and all your current settings are kept.
