RobbieBeats
Dec 07, 2020Aspirant
X4S R7800 Higher Ping
Hi, I recently purchased the X4S R7800 Router. I went through all of the set up this morning. I put my ISP gateway into passthrough mode and disabled the wifi. I've connected my PS5 to the Night...
RobbieBeats
Dec 08, 2020Aspirant
It's an Arris BGW210. I followed instructions online I found to set it to passthrough mode and turn the Wi-Fi off on the gateway.
michaelkenward
Dec 08, 2020Guru - Experienced User
Thanks for the added details. That could be invaluable information for someone who understands this stuff
Do the instructions you used tie in with this?
(1) How To: Properly Configure The Arris BGW-210 For "Bridge Mode" (Walkthrough) : Ubiquiti
Bridge mode is the term I am more familiar with when playing with modem/routers like the BGW210. But bridge mode also means different things in different contexts. (Don't you love it in when techies use strange terms in different ways?)
Here is a more local reference:
Solved: How do I setup bridge mode in the ARRIS BGW210-700 - NETGEAR Communities
Found with this:
Search - NETGEAR Communities – BGW210
I have also seen reports here of AT&T devices being a pig to put into bridge mode.
