JKLE_Cougar
Jun 18, 2023Aspirant
X4S R7800 Throttling LAN ports
Hello, I noticed the other day that my network and mesh wifi system were running slow when ever I would watch youtube videos they would drop in quality and get extremely pixelated and I would hav...
Jun 18, 2023Guru - Experienced User
So why not use the MESH system as your router and wifi system?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
- JKLE_CougarJun 19, 2023Aspirant
I don't use the MESH system as router since I have some port forwarding settings that I need.
I had a Motorola MB8600 originally but they swapped it out to one of theirs since it was not reading right on their end.
The one they gave me is a DOCSIS 3.1 eMTA EU2251
I swapped out the ethernet cable already.
Wifi I am getting good speeds its only hardwire where it's throttled.
I have not done a factory reset on it since I didn't want to lose my port forwarding settings but I can do that as a last resort if no other ideas come up.
- michaelkenwardJun 19, 2023Guru - Experienced User
Where is the R7800 in this system?
Is the anonymous Ubiquiti Mesh system operating in AP mode?
What do you see here in the browser graphical user interface (GUI)?
- Advanced
- LAN Port
- Show Statistics
How I have it setup is like this: Modem > R7800 > WiFi Mesh system in Port 2
WAN is showing 1000M/Full
LAN 1 is my PC that's showing 1000M/Full
LAN 2 is the WiFi Mesh system showing 1000M/Full
LAN 3 is my network printer showing 1000M/Full
LAN 4 is my security/camera system that's showing 100M/Full
