uday_sharma
Oct 05, 2021Aspirant
X4S (R7800)
Hello everyone Thanks for your time to read into this post and kindly pitch-in with your suggestions/recommendations/solutions to my query. I need to connect my X4S (R7800) router to Fibrenet se...
uday_sharma
Oct 06, 2021Aspirant
ONT device is NOKIA make G-2425-G-A
ISP is Airtel Xtreme Fibrenet
michaelkenward
Oct 06, 2021Guru - Experienced User
It isn't easy to track that down.
Is this what you have?
Airtel Xstream Fiber Nokia G2425G-A Gpon ONT Gigabit Dual Band Wifi Router – gavnit.com
If so this is a combined ONT/router.
You don't need any adapters. You just need to work out how to configure things.
You will have two routers n your network.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router.
NOKIA G-2425G A bridge mode - Google Search - NOKIA G-2425G A bridge mode
Sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
- KitsapOct 06, 2021Master
What are you trying to accomplish with your R7800 that you cannot do with your ONT?
If you were to connect the R7800 to the ONT, physically how far apart would they be located? Less than a meter? Greater than 10 meters?
- michaelkenwardOct 06, 2021Guru - Experienced User
Excellent question.
Which features are on the R7800 that aren't on the ONT/router? After all, the R7800 has not, thankfully, gone down the Circle./Armor road. But it does have Anywhere Access that may, or may not, be on the ONT.
