JofAustin
Jul 14, 2021Aspirant
X4S triangle lockups
I have a placement setting issues. I have a Netgear Nighthawk R7500 router set in router mode, and 3 mesh extenders using the one network feature while separating the 2.4G and the 5g names. the mesh...
JofAustin
Thanks, but that beats the purpose of the extender using a single ssid. My guest network is also extended, so I can't use that ssid to 1st extender from the router. The alternative of changing the end nodes, makes it that I manually need to switch networks.
any planned firmware updates from Netgear on this?
Jul 15, 2021Guru - Experienced User
Its not a problem of updates.
Its a problem if daisy chaining and using multiple extenders to try to have a full mesh network with extenders.
Its why if you read these forums, its recommended that if you're needing more than 1 extender, to get an actual mesh network. And you have 3.
The mesh extenders don't have anything controlling them (like an actual mesh network) so they can end up connecting in an improper order that isn't optimal.
will they connect and have 1 ssid. sure.
will they work in the best possible speeds? doubtfull as you've found out
so if you want the performance that you desire, you'll need to change one or 2 of their ssid's so they connect properly.
Or you can leave them as they are and how their performing.
or you can sell them and buy an actual mesh system (make sure its triband with your configuration)
