detweiler
Jan 20, 2026Aspirant
X6 AC3200 R8000 as a Wi-Fi mesh extender
I've been trying to set up my Nighthawk router as a mesh extender for some time now, well ever since Frontier went from the Arris router to the eero router. Definitely no joy there. I have jumped s...
Jan 21, 2026Guru - Experienced User
What actually happens during setup when its been reset (provided you don't connect the R8000 to the spectrum router)?
What error do you get?
What are the led's on it doing?
detweiler
Jan 21, 2026Aspirant
After the reset, I tested the wireless and then wired connection and get the same error.
When accessing the listed URLs, the browser ( Safari, Firefox, Opera,Chrome ) stated the page could not be displayed because the server wasn't responding.
Once the X6 is turned on, the Power LED turns on, the Internet LED flashes and then turns on once the 2.4 GHz and the two 5 GHz LEDs turn on. The 1, 2, 3, 4 LEDs also turn on. Then nothing, even when trying to hit the listed URLs.
- FURRYe38Jan 21, 2026Guru - Experienced User
With the R8000 disconnected from everything, try a 30-30-30 reset on the router. Only LEDs that should come ON is the power and WiFi LEDs with nothing connected to it.
Once the last reset completes, give 1 minute and connect one ethernet PC to the LAN port of there router. Check the PCs networking configuration and see if it get a 192.168.1.x IP address from the router. If it does, try 192.168.1.1 in a web browser.
