LloydOsten
Mar 04, 2021Aspirant
X6 Nighthawk R8000
I just upgraded to the latest software (vV1.0.4.68_10.1.75 ) Now there are some websites that I could previously connect to that I can't connect to now. I think this just started happening with the s...
antinode
Mar 04, 2021Guru
> [...] Is there any place I could download older versions of the
> software?
Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions. (In the User Manual, look for "firmware", and,
especially, for a topic like "Manually Upload Firmware to the Router".)
When that fails because of a deficient User Manual, try:
