BradHgt
Apr 14, 2021Follower
X6 R7850 Can't Update Firmware
.I have a Netgear Nighthawk X^ R7850 ... Bought it last year. It is currently running firmware Rev 1.0.4.46_10.0.2. For weeks/months now, it has been telling me that there's a firmware upgrade for th...
joseosanchez
Jul 09, 2021Aspirant
Dis you guys got this resolved? If so how? I am having the same issue.
Thank you
Jose
Thank you
Jose
TexasBlack
Aug 22, 2021Aspirant
I kept getting the same firmware error when I tried to load the latest version. I got it to work after a few tries. You have to update from 1.0.4.46 to 1.0.5.48 first (the next firmware version in the upgrade sequence). After you're successfully on 1.0.5.48 you can jump to 1.0.5.74.
- joseosanchezAug 23, 2021Aspirant
Great that is good news. Do you know where to get the previous versions of the firmware? I can only find the latest one in the netgear website.
Thank you
- michaelkenwardAug 23, 2021Guru - Experienced User
I don't know where you were looking for firmware, but visit the support pages:
Support | NETGEAR
Feed in your model number and you there should be a library of firmware that stretches back to the original release. Take your pick and then follow these instructions:How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
