Tacocopter
Dec 27, 2019Tutor
X6 R7900 not giving correct internet speeds
Recently upgraded my internet package from 175down to gigabit. I've been able to hit my gigabit speed when directly connected to my modem but I can't get close when using my router. Usering wired co...
- Dec 27, 2019
Firmware on your router?
What modem are you using?
have you tried factory resetting your router and starting over? occassinoally the prior qos settings are retained and limit speeds.
If you factory reset, push and hold reset while the device is fully powered on. It should take 7-15 seconds but the lights will change when you've held it long enough.
Dec 27, 2019Guru - Experienced User
Tacocopter
Dec 29, 2019Tutor
Looks like a factory reset fixed everything. I feel so silly that I didn't try it earlier.
- plemansDec 30, 2019Guru - Experienced User
glad to hear you got it working!
