Andrew1997
Jul 29, 2021Tutor
X6 R8000 - Web Services Management Missing Options
Missing options on Web Services Management - on latest FW. Any ideas?
michaelkenward
Nov 14, 2021Guru - Experienced User
And that firmware version is?
Does it come back to life if you revert to an earlier version?
Andrew1997
Nov 14, 2021Tutor
In the end I had to revert mine back to the previous version. Reason I upgraded as it seemed the new FW version was faster, however, the web services management then went missing.
- FURRYe38Nov 14, 2021Guru - Experienced User
NG maybe moving away from Remote Managment from the UI and going to the NightHawk app for any remote access. Were seeing this on other product lines....
- michaelkenwardNov 14, 2021Guru - Experienced User
