wkus
Dec 08, 2021Follower
X6-R8000 in continuous restart loop
Hi, can someone help me? The Nighthawk R8000 is in continuous restart loop. It happened all of a sudden, may I know what is wrong with it and how to fix it? I have tried contacting the local netge...
Dec 08, 2021Guru - Experienced User
Have you tried a factory reset? Push and hold reset for up to 30 seconds while its powered on.
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
