Gizmodo876
Sep 01, 2023Aspirant
X6 R8000 keeps dropping to 100Mbps wired
firmware V1.0.4.84_10.1.84 1130Mbps down 110Mbps up DOCSIS 3.1 cable connection connected to WAN port by CAT5e. R8000 in AP mode. 95% of the time, my r8000 runs fine, speed tests showing ~950to9...
Gizmodo876
Sep 02, 2023Aspirant
It’s a virgin media Hub 4 it’s connected to. Changing cables to Cat6 isn’t an option (Cat5e perfectly capable of carrying a full duplex gigabit signal over 100m my run is only around 20m with shallow radius corners) it would mean having to rip plasterboard off of most of the bottom floor of my home to get from where the AP is to the cable modem. But the cable is known good with continuity between ends. When the problem occurs the link between modem and AP (WAN port) is the only connection to remain at 1000mbps, all the LAN ports drop to 100. Tested all cables with Ethernet tester and multimeter all good.
Gizmodo876
i think Virgin media Hub 4 is a rebranded ARRIS TG2492S/CE
- michaelkenwardSep 02, 2023Guru - Experienced User
If so, that is a "gateway". a modem/router.
In AP mode, the R8000 doesn't have much that it can do, or that you can do to it.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
