Luke_G
Aug 30, 2017Tutor
X6S Extender – Any Benefit with Multiple X6S Range Extenders?
If I were to have multiple X6S Range Extenders installed in a house/building would each seperate X6S talk with eachother to get better speeds? I see that on the product page that it has a dedicated W...
- Aug 30, 2017
Hi Luke_G,
Thanks for your question. Yes, If you have multiple X6S, you can connect them to get a larger network one behind another. The downstream X6S would be connecting its backhaul to the fronthaul of the upstream X6S, thus sharing it's connection with other devices. The benefit here is that you can continue using the single ssid and range would be better than just using one.
Another option is to connect in Access point mode where you can continue using the downstream tri-band radios simultaneously.
arunkmony
Aug 30, 2017NETGEAR Employee Retired
Hi Luke_G,
