Dopply's avatar
Dopply
Follower
Aug 31, 2017
X6S Extender – Can it have a multiple SSID's like a Guest SSID?
Is it able to have multiple SSID:s ?
Like a Guest SSID..
  • Hi Dopply,
    Thanks for your question. Nighthawk X6S can have multiple SSIDs like one for 2.4G and one for 5G in extender mode or one for each of the three bands in AP mode. This is configurable with different password also that you can use if you don't want to share your main network with others.
    Guest network is not supported.
    Please visit http://www.netgear.com/landings/ex8000/ for more details.
1 Reply
  • arunkmony's avatar
    arunkmony
    NETGEAR Employee Retired
    Hi Dopply,
