robt81's avatar
robt81
Follower
Aug 30, 2017
X6S Extender – What is the Maximum Range?
The X6S looks like a mighty fine device. What would be the maximum range the device can push to?(for example if you have a very large house, maybe 3 or so stories tall)
  • Hi robt81,
    Thank you very much for your question.
    With the patented FastLane3 technology Nighthawk X6S Extender provides you unparalleled performance and range which you don't get with traditional extenders which share bandwidth between clients and router. Not only that you also can get better roaming experience by using the same SSID as your router on your extender network.
    This new breakthrough Nighthawk extender broadens your network coverage with faster speeds up to an additional 2,500 square feet  while reducing interference so smartphones, tablets and computers all stay connected to stream, game or browse the internet. The coverage is dependent on the layout of a property, the type of materials used in construction, or limitations around placement of the router.
1 Reply
  • arunkmony's avatar
    arunkmony
    NETGEAR Employee Retired
    Hi robt81,
