jmpedron's avatar
jmpedron
Follower
Aug 30, 2017
X6S Extender – Will it connect to Orbi's dedicated 5G backhaul?
  • arunkmony's avatar
    Aug 30, 2017
    Hi jmpedron,
    Thanks for your question. Nighthawk X6S is intended to work with any router or gateway and provide extreme speed and coverage by using one of the tri-band radios to connect with the router. It can work with Orbi but cannot connect to the dedicated backhaul of Orbi since Orbi is a closed system.
