bmgarcia
Sep 05, 2017Tutor
X6S Extender - Extended placement
If I buy this extender where do you suggest i place it? My router is set up in the main office towards the front of the building. Should this be set up in the middle or towards the back?
- Sep 05, 2017
Positioning of extender within the home depends on the layout, where your router is and how good your router is etc. On Nighthawk X6S, there are intelligent LED indicators which will guide you to place it in the best position. You can take a look at the Quick Start Guide that comes with the product for more details on how the led's help you with it. It's pretty straighforward. To learn more, please visit http://www.netgear.com/landings/ex8000/
Sep 06, 2017Guru - Experienced User
As noted by arunkmony, there are indicators to help you find the best placement. The best spot will depend in part on the building construction.
But generally speaking, you want the X6S to be able to reach the router with good signal, and also reach the client devices in the rear of the buiding. Normally that means placing the extender midway between the router and the back of the building.
