MON5TERMATT's avatar
MON5TERMATT
Follower
Aug 30, 2017
X6S Extender - Will it support multiple networks?
  • arunkmony's avatar
    Aug 31, 2017
    Hi MONSTERMATT,
    Thanks for your question. I am not sure I understood multiple networks clearly. If you mean to say more than one X6S talking to your router, yes, that's possible. If you are talking about different SSID combinations, yes there is flexibility to configure X6S extender with same ssid or different ssid as your router.
