kP206
Dec 12, 2021Guide
Xbox NAT is set to Strict or Moderate why playing online.
I have the CAX80 Modem and wifi combo and I found this help link on netgears website.
So my question is, can I skip 1-4? Since I have the combo Modem and Wifi unit.
1 Reply
Yes you can leave uPnP enabled and you don't need to set up any Port Forwarding or Triggering.
You should be getting OPEN NAT if you connect just 1 xbox to the modem. How mine works.
FYI, Netgear has set up a community forum specifically for the Cable Modem products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
