atistang
Dec 01, 2017Aspirant
Xbox One and Windows Store on my PC will not install or load games with IPv6 enabled
ISP is Spectrum. I setup IPv6 on this router almost a year ago. Everything was good immediatly there after. Then I started noticing occationaly trying to start a game on my Xbox would give me an e...
- Dec 07, 2017
I think it has been resolved. I got a message from an Xbox Engineer last night that said they made a few changes and to give it a go. Since then everything has been fine.
JamesGL
Dec 07, 2017NETGEAR Employee Retired
Hi atistang,
Have you check with spectrum regarding the IPv6 connection if they are experiencing issues from their end?
What is the firmware version of the router?
- atistangDec 07, 2017Aspirant
- JamesGLDec 07, 2017NETGEAR Employee Retired
Hi atistang,
Glad to know it works now. I will tag your post as accepted solution.
