TheMajorTool
Nov 09, 2015Aspirant
Xbox One Moderate NAT -- Black Ops 3
New to the forums and really looking for some help with my router. So, I just bought a new Nighthawk r7000 router to updgrade my gaming and overall internet experience. Unfortunately, I'm not a very tech savy person. So, below is my infomation and some of the solutions that I've tried. Any advice woudl be greatly apprecaited -- I'm at work right, so I'll try and solutions after work today.
The goal is optmize my experience and get my NAT to Open -- it's OPEN on the detailed network page but MODERATE on the Black Ops 3 menu screen.
Provider: Time Warner Cable
Connection: 60/10 -- Xbox One is wired into router, router is wired into modem; I've seen some posts about "bridge connections" but I have no idea what that means.
Assigned IP for my Xbox One in Admin Setup on router
Assigned default DMZ for Xbox One
Enabled uPnP
Ports Forwared:
TCP: 53, 80, 3074/5
UDP:53, 88, 500, 3074/5, 3544, 4500
Now, I don't know anything about the settings on my cable modem, but I'm happy to make any adjustments.
Thanks in advance for any help and advice!
Casey
You are supposed to use only one of available options to open ports (i.e. uPnP, Port forwarding, DMZ), not all of them. Pick one and disable the others. uPnP is preferred because it's automatic, but it depends on the quality of Netgear's implementation. If you find it doesn't work, then proceed to port forwarding. DMZ is the least preferred because of the danger of exposing your console directly to the Internet.
It's important to know whether your modem has a built in router. If it does, then you will have to contend with two layers of NAT and, therefore, two layers of closed ports. Bridging the modem disables the router functionality and eliminates this extra NAT layer. One way to tell if your modem has a router is to look at the IP address assigned to the yellow Internet port of your R7000. If it begins with either 10.x.y.z, 192.168.y.z, or 172.16.y.z then the modem is a router. Another way to tell is if the modem has built-in Wi-Fi.
- TheMajorToolAspirant
Thanks -- If the modem has built in WiFi, how do I disable it?
I had no idea that you were only suppose to choose one of the three options -- really appreciate that. I suspect that I'm dealing with two layrs of NAT and that's probably causing some of the issues.
You will have to log into your modem. You should be able to find its IP address by logging into your R7000. It will be listed as the Gateway IP address on the Internet page.
