Anger756
Jul 24, 2022Aspirant
Xbox Series X connection Slow
I have a Nighthawk R8000 router. My Xbox Series X speeds are slow compared to my other devices (phone, computer, etc.). I have my Xbox wired with a Cat6 Ethernet cable. My internet when connected to ...
Jul 25, 2022Guru - Experienced User
Its usually because the xbox is testing off a different server and that server isn't saturating it. Games don't take that much bandwidth so even getting 250mbps is way more than will be needed for gaming. The only benefit for faster speeds with that system is the games download quicker.
Anger756
Jul 25, 2022Aspirant
plemans that makes sense. What doesn't make sense is when I tried a different router I was consistently getting 400 mbps instead of 250 mbps. When I switched back to my Nighthawk router it tested at 250 mbps again. Could a setting on the router or Xbox be slowing it down?
- plemansJul 25, 2022Guru - Experienced User
What modem/gateway is the router connected to?
Make sure access control, traffic monitoring, and parental controls are disabled.
Are you using IPv6?
