Anger756
Jul 24, 2022Aspirant
Xbox Series X connection Slow
I have a Nighthawk R8000 router. My Xbox Series X speeds are slow compared to my other devices (phone, computer, etc.). I have my Xbox wired with a Cat6 Ethernet cable. My internet when connected to ...
Anger756
Jul 25, 2022Aspirant
plemans that makes sense. What doesn't make sense is when I tried a different router I was consistently getting 400 mbps instead of 250 mbps. When I switched back to my Nighthawk router it tested at 250 mbps again. Could a setting on the router or Xbox be slowing it down?
Jul 25, 2022Guru - Experienced User
What modem/gateway is the router connected to?
Make sure access control, traffic monitoring, and parental controls are disabled.
Are you using IPv6?
