Anger756
Jul 24, 2022Aspirant
Xbox Series X connection Slow
I have a Nighthawk R8000 router. My Xbox Series X speeds are slow compared to my other devices (phone, computer, etc.). I have my Xbox wired with a Cat6 Ethernet cable. My internet when connected to ...
Jul 26, 2022Guru - Experienced User
Try enabling ipv6
Anger756
Jul 26, 2022Aspirant
I enabled IPv6 and chose the "auto detect" option. Is that the right option to choose? When I tested the speed again it went up to 280 mbps from 250 mbps. Any other suggestions?
- plemansJul 26, 2022Guru - Experienced User
If everything else is getting full speed but the xbox, I'd still be looking at how the xbox is testing. Maybe its choosing a poor server when ran through the router.
- Anger756Jul 26, 2022AspirantOne thing that is odd is that my dynamic QoS is disabled and always has been but when I press "Apply" with out changing a single setting on my router, my Xbox starts testing at full speed (400 mbps). I've done this every time it starts testing low and it works every time but for only about 12-24 hours. Any idea why this might be? Again, my dynamic QoS is not enabled so this is very confusing.
- plemansJul 27, 2022Guru - Experienced User
Try the factory reset. leave everything at defaults. test the speeds then
Reason I said that is I've seen ctf (needed to hit gigabit speeds over wan) get disabled when those services are activated and not re-enabled when they are disabled.
