hear136x
Jan 20, 2021Follower
Xbox series x double nat
I have had a double nat on my Xbox since moving into my apartment. I plug my router into the wall Ethernet plug. I have tried putting the router into bridge mode, and enabling the access point in the ...
michaelkenward
Jan 21, 2021Guru - Experienced User
Not a new one, I fear. Try this:
Search - NETGEAR Communities – xbox nat
You can even refine that to your device.
There should be useful guidance in there.
Don't expect much of the R6120. It has LAN ports that are limited to 100 Mbps. (Ignore the 10 Mbps in the manual.) That is slower than many new Internet services.
hear136x wrote:
I have tried putting the router into bridge mode, and enabling the access point in the router settings.
That is no good unless you have a modem/router ion front of the R6120.
