pasky01's avatar
pasky01
XFinity Router - Enable Bridge Mode or Not
My Xfinity modem/router crapped out over the weekend. I was able to grab a replacement at a Verizon store. I have a Gig connection. I have always set the Xfinity box to bridge mode and, of course, cable directly into my R9000. This time I decided to not bridge the connection. So I now have two additional wifi connections outside of the R9000 firewall. I'm retired at home so I have no need for a DMZ. I also have no need for a VPN.
1) It seems to be working fine
2) I see no degradation in response time
Can someone with more network expertise please comment on the pluses and minuses for doing this? Rather trust you folks than just looking for answeres on the net.
Thanks!!
  • > My Xfinity modem/router [...] a replacement at a Verizon store. [...]
       Not a very detailed description of either device.
    > [...] This time I decided to not bridge the connection. [...]
       Any reason?
    > [...] So I now have two additional wifi connections outside of the
    > R9000 firewall. [...]
       Are you using them?  (Are your neighbors?)
       "It"?  _What_, exactly?
       Cascading multiple routers can cause multiple problems, but,
    depending on what you do, you might never notice.  For example, if you
    connect one client device (computer, ...) to one router, and another
    client device to another router, then communication between those client
    devices might fail, but both might still be able to access the Internet.
       For information on a different one-router configuration which would
    leave all your wireless-network radios active, visit
    http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Look for "Use the Router as a
    WiFi Access Point".  For a list of router features which this
    method disables, see:
          https://kb.netgear.com/26765/
       As usual, many things are possible.
  • plemans's avatar
    its perfectly fine to do. I would recommend putting the R9000 in AP mode so that you don't have a double nat issue on your network.
    https://kb.netgear.com/30186/What-is-Double-NAT
    Also, I'd recommend seperating out the wifi channels between the 2 routers so they don't create interference with each other.
    so for 2.4ghz. put one on 1-6-11 and the other router on one of the other 2 channels.
    for 5ghz, i'd recommend one router on the higher channels and one on the lower channels.
       Any reason?
    • pasky01's avatar
      pasky01
      Thanks. All of my wired devices connect to the R9000. Your suggestion about splitting the wifi channels I will definitely look into. The "it seems to be working" refers to response time. I see no degradation.
      On the lighter side, I'm 69 and live in a retirement community. I have WPA2-PSK enabled in the wireless settings and also on my two extenders. As for my neighbors, think IBM AT's and dot matrix printers.
      Thanks again.
