robrice529
Feb 11, 2022Star
Xfinity Speed Upgrade
My xfinity internet plan was recently upgraded from 200 DN/5 UP to 300 DN/10 UP. I didn't see any difference in speed tests, so I contacted xfinity support. The tech did some update on their end an...
Feb 11, 2022Guru - Experienced User
how are you testing speeds?
What device, site, are you testing on?
Wired? wireless?
- robrice529Feb 11, 2022Star
I use the windows speed test app or the ookla website. Get same speeds either way. My laptop does not have a port for wired connection, so I am testing with the wireless connection. Was considering using another laptop to test with wired connection. Haven't had access to that yet. I just figured if the upload changed (doubled), I should have seen some difference in download.
- plemansFeb 11, 2022Guru - Experienced User
test your wired connection.
Many factors influence wireless speeds. LIke if your laptop has a simple 1x1 wireless card in it versus a 2x2 antenna setup. Or if theres wireless interference, etc.
So first test wired to see if the device is getting its full speed.
If it is, then try other devices.
What actual wireless card is in your laptop?
Realtek 8821CE Wireless LAN 802.11ac PCI-E NIC
Max Trans: 1500
Link Speed: 260/260
