Hdaveyboy
Nov 15, 2020Aspirant
XR 500 can't detect internet but AC 1750 does just fine.
Hi, I recently purchased an XR 500 and tried all day yesterday to get it to work. My old router is a Nighthawk AC 1750 and it still works. I live in montana and have dsl service through a comtrend vr...
Hdaveyboy
antinode wrote:> [...] My old router is a Nighthawk AC 1750 and it still works. [...]
My old router is a R6700v3
"AC 1750" is a speed, not a model number. Look for "Model" on the
product label.
The non-psychics in your audience also can't see how it's configured.
Here are some creenshots of the configurations the last screenshot is the R6700v3's config, sorry about order, and the first three are the new router's config screen shots.
> [...] comtrend vr 3030 modem [...]
That looks to be a simple modem. If your DSL connection uses PPPoE,
then you'd need to configure that on your (new) router.
As far as I know the modem's not PPPoE
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read.
> [...] The internet light is white/blinking white [...]
What are _all_ the LEDs doing?
All the lights were white
> [...] It must be my damned modem somehow not giving the XR 500 what
> it requires.
Or, your (new) router is not giving your ISP what _it_ requires. Or
something else is wrong.
Hdaveyboy
I also tried going back to an older firmware but now am back to the newest one I could find.
In AP modem it works when it's plugged into the old router.
- antinodeNov 15, 2020Guru
> Here are some creenshots [...]
I can't (yet) see your pictures. In-line images must be approved by
a moderator before others can see them. The time required varies.
Attachments have no such limitation. Of course, attachments have their
own one-per-message limitation.> As far as I know the modem's not PPPoE
It's a router question, not a modem question. Something like: "Does
your Internet connection require a login?".> All the lights were white
Even the USB port-status indicators?
> newest one I could find.As always, actual version numbers would be more useful than your
opinion of what's "newest" today (or "older").- HdaveyboyNov 15, 2020Aspirant
antinode wrote:> Here are some creenshots [...]
opinion of what's "newest" today (or "older").No my internet connection does not require a login.
The USB lights were not on, only power, internet, 2.4ghz, 5ghz, and eth1
However when i plugged in a usb drive the light did light up and transferred a file over fine.
The newest version number which i'm running now is 2.3.2.66, and the old one i tried was 2.3.2.32
Without changing anything in the XR500's settings, if i plug in the XR500's internet cable to the old router's eth1, while the old router is connected to the internet, its working just fine.
