roos5's avatar
roos5
Guide
Oct 02, 2021
XR1000 Connection status disconnected
Hello team,
I got my new XR1000, so far I’m loving it, after the initial setup I realize that my connection status sows “ disconnected” but I do have internet connection, still there somethings that are not working properly:
1- Ping heatmap  is not working properly, I get more Ping failed that successful.
2- Upnp check mark doesn’t stay checked, portmap table is empty most of the time.
3- internet speed test are very inconsistent in my devices ( Mac, cell phone, Xbox, etc), difference is very noticeable.  However results are more consistent in “Connection benchmark” within the router.
im not sure if  these listed issues are being caused by the connection status issue, but this never happened to me with my XR500.
ive done 2 factory reset so far but no luck.  My ISP router is in bridge mode, I only have my XR1000 connected to it.
  • plemans's avatar
    what isp router do you have? Some of them don't function properly in bridge mode.
    Try putting it back in router mode and putting the netgear's IP address into its DMZ.
  • FURRYe38's avatar
    Please visit and post about this over in the NH Gaming router forum:
    https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/bd-p/en-home-nighthawk-pro-gaming-routers
    Thank you.
    roos5 wrote:
    Hello team,
