cjbutterfly
Aug 07, 2019Guide
xr500 how do i create a seperate 2g and 5g option
hi there, virgin recently came to my house to fix my internet as my speed was no where near the 200mb it was supposed to be and they changed a setting on my netgear router to enable seperate 2g and 5...
- Aug 07, 2019Thank you :)
Aug 07, 2019Guru - Experienced User
Page 87 of the manual walks through enabling/disabling smart connect.
https://www.netgear.com/support/product/XR500.aspx
