jay1989
Sep 25, 2018Initiate
XR500 internet issues
Hi, I recently upgraded to the NightHawk XR 500 in a bid to optimise my online gaming experience. I am on Aussie Broadbany fixed wireless nbn. My problem is that I haveconnected everything as pe...
- Sep 25, 2018My NBN is via a tower much like phone reception except slower.... You do not require user/password detail, just a direct cable to the NBN box installed on our wall.
After hours of trouble shooting I managed to fix the problem. I initially tried the auto setup which wanted internet via PPPoE but as stated previously my service doesnt require login details. This caused me to set up manually. I turned off the router and nbn box for 10min. Started NBN box up by itself and left it for 10min. I then booted the XR500 and did the auto setup again which detected my internet!! Problem solved :-)
shadowsports
Sep 25, 2018Hero
Greetings,
I haven't had a chance to see the Duma OS yet. Your post should probably be moved to the "Nighthawk Pro Gaming" section of the forums as this not the right area.
Is your NBN connected to sattelite? I traded post with another Aussie user who mentioned something about needing to speak with the provider regarding additional set up requirements. Like you, his internet LED turned white, but he didn't have internet.
Would you mind sharing how the service works with us? I know you get a public IP from the box. Maybe you need to configure the conection type as static in the router and enter in IP, SM and gateway.
I think the first thing to do would be to connect a PC directly to the NBN box and confirm you have internet. It sounds like you do based on the description, however, you should not have to enable VPN or anonimize your device to gain connectivity. While you are troubleshooting, I would not employ any software that changes your IP scheme.
Happy to help more with additional information.
jay1989
- shadowsportsSep 25, 2018Hero
Good work! We like to hear a positive result. Hope you are enjoying the new router.
