jgg1950
Feb 19, 2022Apprentice
xx70a configuration
Does anyone know how to save xx70a full configuation for future use/record if a factory reset needs to be done ? Model field doesn't have xx70a or MR60. Thanks
Feb 19, 2022Guru - Experienced User
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
- jgg1950Feb 19, 2022Apprentice
Thanks
