chxu
Feb 05, 2022Follower
Yamaha MusicCast does not appear in wifi
My routher is Nighthawk X6S AC3000 Tri-Band WiFi Router Model R7900P. I connect my yamaha r-n303bl network Receiver with Cable to Router directly. Airplay can find the Receiver and works very well. I...
Feb 06, 2022Guru - Experienced User
You'd have to check with yamaha on specifics with their device. They'll be the expert on setting it up.
- michaelkenwardFeb 06, 2022Guru - Experienced User
