rstorms20
Jul 29, 2018Aspirant
Your favorite R7500v2 Firmware Version
Hi, I've been very frustrated with the last 3 updates for my R7500v2 Router. They drastically changed my ping speed and my network speed altogether. Does anyone have any suggestions? I am currently u...
- Jul 30, 2018
Tried a factory reset after each firmware upgrade?
michaelkenward
Jul 30, 2018Guru - Experienced User
rstorms20
Jul 30, 2018Aspirant
I had that thought yesterday so I did a factory reset and it worked!! Thanks for responding. It definitely took care of my problems.
- michaelkenwardJul 30, 2018Guru - Experienced User
That's good news. And yet some people still refuse to try it.
Netgear should make this ppssibility clearer in the release notes.
- rstorms20Jul 30, 2018AspirantI agree it should say something like "for best performance results do a factory reset after an update."
I find this to be true for pretty much everything now days, especially smart phones and PC's.- myerswJul 30, 2018Master
I always view the reset after an update as not needed in most cases, at least mine. THAT SAID, if there is an issue after the update then a reset is in order as things do seem to change that break old configurations. One important thing DO NOT use an old backup after a reset as you will put things back the way they were before the update.
