rstorms20
Jul 29, 2018Aspirant
Your favorite R7500v2 Firmware Version
Hi, I've been very frustrated with the last 3 updates for my R7500v2 Router. They drastically changed my ping speed and my network speed altogether. Does anyone have any suggestions? I am currently u...
- Jul 30, 2018
Tried a factory reset after each firmware upgrade?
rstorms20
Jul 30, 2018Aspirant
I had that thought yesterday so I did a factory reset and it worked!! Thanks for responding. It definitely took care of my problems.
michaelkenward
Jul 30, 2018Guru - Experienced User
That's good news. And yet some people still refuse to try it.
Netgear should make this ppssibility clearer in the release notes.
- rstorms20Jul 30, 2018AspirantI agree it should say something like "for best performance results do a factory reset after an update."
I find this to be true for pretty much everything now days, especially smart phones and PC's.- myerswJul 30, 2018Master
I always view the reset after an update as not needed in most cases, at least mine. THAT SAID, if there is an issue after the update then a reset is in order as things do seem to change that break old configurations. One important thing DO NOT use an old backup after a reset as you will put things back the way they were before the update.
- SonofasheperdAug 27, 2018AspirantHi guys, I hope it is ok to continue this post. I'm having similar issues. My PS4 is almost unplayable until I do a hard reset then it gets better. But the next day it's bad again. Qos was not checked in mine after the update. I'm lost as to where to look next. Any idea?
