mzagaja
Dec 22, 2021Aspirant
Zoom Calls Intermittently Drop Audio When Wired
I have a Netgear R7000P and for unknown reasons when using Zoom I get semi-regular audio drops of 3-10 seconds. This only seems to occur when I am connected via a hardwire. A wireless connection to t...
- Dec 22, 2021
IF the power cycle doesn't solve this, a full on factory reset will be a next step.
Dec 22, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
mzagaja
Firmware is V1.3.1.64_10.1.36
The ONT is a Nokia. G-211M-C MRev: 03.
I only use the "auto-update" feature of the Netgear.
No factory reset. It seems like it would be a lot of work to do this if there isn't a guarentee or strong evidence it would resolve this issue otherwise. Is it really worth trying that?
I will try the power off and then on tonight.
- FURRYe38Dec 22, 2021Guru - Experienced User
- FURRYe38Mar 15, 2022Guru - Experienced User
Any progress on this?
- mzagajaMar 15, 2022Aspirant
Ran a Factory Reset over the weekend and then noticed my speeds on my 500Mbps connection dropped to 300Mbps. I disabled NAT firewall protection along with ping and DoS protection and started to see expected 500Mbps speeds. No issues on hours of Zoom the past two days with this configuration, so will consider it a win.
You may want to keep Firewall enabled.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
