mzagaja
Dec 22, 2021Aspirant
Zoom Calls Intermittently Drop Audio When Wired
I have a Netgear R7000P and for unknown reasons when using Zoom I get semi-regular audio drops of 3-10 seconds. This only seems to occur when I am connected via a hardwire. A wireless connection to t...
- Dec 22, 2021
IF the power cycle doesn't solve this, a full on factory reset will be a next step.
mzagaja
Firmware is V1.3.1.64_10.1.36
The ONT is a Nokia. G-211M-C MRev: 03.
I only use the "auto-update" feature of the Netgear.
No factory reset. It seems like it would be a lot of work to do this if there isn't a guarentee or strong evidence it would resolve this issue otherwise. Is it really worth trying that?
I will try the power off and then on tonight.
Dec 22, 2021Guru - Experienced User
