joeb3817
Aug 24, 2024Aspirant
Zyxcel AP
Will connecting a Zyxcel AC1200 to a Netgear RAXE300 be possible? or cause problems on the network?
Aug 24, 2024Guru - Experienced User
Should be able to.
You just hardwire it in.
Or is there something specific you're worried about?
- joeb3817Aug 24, 2024Aspirant
Heard that some Zyxcel devices do not play well with other manufacturers.
Just want to avoid problems when I move it into the new space..
