sion303
Jun 04, 2018Follower
COLLEGARE IN CASCATA D6220 A VODAFON STATION REVOLUTION
SALVE VORREI USARE IL MIO NETGEAR AC1200 MODELLO D6220 IN CASCATA CON IL MODEM VODAFONE STATION REVOLUTION....OVVIAMENTE HO GIA VISTO UNA DISCUSSIONE PRECEDENTE MA NON SONO RIUSCITO A FARLO FUNZIONAR...
antinode
Jun 04, 2018Guru
> [...] D6220 IN CASCATA CON IL MODEM VODAFONE STATION REVOLUTION [...]
The Vodafone Station Revolution seems to be a DSL modem+router with
"Porte Telefono".
Cascading multiple routers can cause multiple problems.
I assume that you want to use the Vodafone unit as your main router.
The D6220 could be used as a wireless access point (rather than as a
full-function router). In English, visit http://netgear.com/support ,
put in your model number, and look for Documentation. Get the User
Manual. Look for "Use the Modem Router as a WiFi Access Point Only".
In Italian, you're on your own.
> [...] UNA DISCUSSIONE PRECEDENTE [...]
I can't guess what you were reading.
> [...] NON SONO RIUSCITO [...]
"NON SONO RIUSCITO" is not a useful problem description. It does
not say what you did. It does not say what happened when you did it.
As usual, showing actual actions with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
