ijon
Aug 06, 2017Aspirant
D3600 loses all settings on every reboot
Hi, After upgrade to version V1.0.0.64_1.0.1 D3600 loses all settings on every reboot. Could you provide instruction how to downgrade this firmware to version V1.0.0.47_1.0.1 on this device ?
incognito0
Aug 24, 2017Aspirant
Ref: D3600-V1.0.0.64_1.0.1. Firmware. Win10, Hi All, for what it is worth I have also tried all the above with no success. I have installed a firmware backup which gets the router D3600 working but if I disconnect the power, then yes, all the setting disappears. Every now and then something happens with the connection from the exchange which causes the connection to disconnect. I can live with this if I am home as I can start the router and go through the setup process again but this is no good if the connection goes down and it is just my wife and kids at home. They will be without the internet. Please Netgear, I hope you are listening as this makes my router virtually unusable.
vitogala
Aug 25, 2017Tutor
Please open a ticket on https://my.netgear.com
you will be able to resolve with customer support describing your problem with this specifc firmware.
- Anthony1992Aug 25, 2017Aspirant
I send ticket but anyone respond.
There is bug in this firmware version, there is no solution that work.
- vitogalaAug 25, 2017Tutor
Call telephone support.
they sent me a resolution workaround and an intermediate firmware.
I live in Italy, can yo send me your firmware?
