ijon
Aug 06, 2017Aspirant
D3600 loses all settings on every reboot
Hi, After upgrade to version V1.0.0.64_1.0.1 D3600 loses all settings on every reboot. Could you provide instruction how to downgrade this firmware to version V1.0.0.47_1.0.1 on this device ?
t3als
Sep 30, 2017Aspirant
New firmware has been released, however i can't even install it. If i try to upload via the web ui it says "Firmware upgrade failed. Please check your file.". When I try to check for updates it says "No Internet connection is detected. The router cannot check the NETGEAR server for updated firmware. After setting up your Internet connection, go to the Router Upgrade screen to check for updated firmware.". The TFTP method doesn't even work. The router is probably semi-bricked at this point.
